Like Mark suggested, you can create the geoprocessor object by import arcgisscripting module to instantiate the geoprocessor object.So, Replace:
import sys, string, os, win32com.client
gp = win32com.client.Dispatch("esriGeoprocessing.GpDispatch.1")
With:
import sys, string, os, arcgisscripting
gp = arcgisscripting.create()
If you want to use the new Arcpy module, you've got more work to do. You've got to modify the code as below:
#BatchClipFCs.py
#Author
# Dan Patterson
# Dept of Geography and Environmental Studies
# Carleton University, Ottawa, Canada
# Dan_Patterson@carleton.ca
#Purpose
# Batch clips feature classes (eg shapefiles) in a project
# and writes them to a folder.
# Many batch clip examples exist, this is compiled for demonstration
# purpose for a class
#Properties (right-click on the tool and specify the following)
#General
# Name BatchClipFCs
# Label Batch Clip Feature Classes
# Desc Batch clip feature classes (eg shapefiles) and saves
# them to a folder.
#Source BatchClipFCs.py
#Parameter list
# Parameter Properties
# Display Name Data type Type Direction MultiValue
# argv[1] Feature(s) to clip Feature Layer Required Input Yes
# argv[2] Polygon clip layer Feature Layer Required Input No
# argv[3] Append to output String Optional Input No
# filename
# argv[4] Output folder Folder Required Input No
#Import the standard modules
# Get a list of feature classes (shapefiles)
# Get the clip feature class
# Get the optional text to append to the filename output filename
# Get the output folder
# Usage: BatchClipFCs <Input_Features> <ClipWith> <optional_text> <Output_Workspace>
# Import system modules, Create the Geoprocessor object and
# Load required toolboxes...
import sys, string, os, arcpy
# Script arguments...
FCsToClip = arcpy.GetParameterAsText(0) #a list of features
fcs = string.split(FCsToClip, ";") #split into a list
clipWith = arcpy.GetParameterAsText(1) #clip layer
desc = arcpy.Describe(clipWith)
clipWithType = desc.ShapeType
addToName = arcpy.GetParameterAsText(2) #optional text to append to output name
if(addToName == "#"):
addToName = ""
outputFolder = arcpy.GetParameterAsText(3) #a folder
arcpy.AddMessage("\n" + "Batch Clip Feature layers" + "\n" )
if (clipWithType == "Polygon"):
for fc in fcs:
try:
fc=fc.replace("'","") #check if a layers name has been changed
desc = arcpy.Describe(fc)
fcDataType = desc.DataType
arcpy.AddMessage("Data type = " + fcDataType)
if(fcDataType == "FeatureClass"): # Feature class on disk
theName = str(os.path.split(fc)[1])
outFile = outputFolder + "\\" + theName + addToName + ".shp"
else: # Feature layer
FullName = desc.CatalogPath
theName = (os.path.split(FullName)[1]).replace(".shp","")
theName = str(fc).replace(" ","_")
arcpy.AddMessage("Output file from layer " + outFile)
arcpy.AddMessage("Clipping " + str(fcDataType) + ": " + fc + " Saving to: " + outFile + "\n")
try:
arcpy.Clip_analysis(fc, clipWith, outFile, "")
except:
arcpy.AddMessage("Could not clip " + fc + " with " + clipWith + " to " + outFile)
except:
arcpy.AddMessage("cannot describe" + fc)
else:
arcpy.AddMessage (clipWith + " is not a polygon layer, clipping terminated" )
Hope that you get the idea!Cheer...
