Populating ListView From shapefile
1483
05-01-2013 12:01 AM
HushamHassan
I have a listview in  my form I need to populate with the selected feature record,  my code fill all the field in one columns, I need to show only 5 columns in my listview.  here is my code so far.
Dim nCols As Integer              nCols = pFeature.Fields.FieldCount              For i = 2 To nCols - 1                  Me.Listsheet.Items.Add(pFeature.Fields.Field(i).Name)                 Me.Listsheet.Items.Add(pFeature.Value(i))               Next
Regards
BarbaraSchneider1
first you have do define the header for your listView:
For i = 0 To pFeature.Fields.FieldCount - 1     strFieldname = pFeature.Fields.Field(i).Name     pColHeader = New ColumnHeader()     pColHeader.Text = strFieldname     Me.Listsheet.Columns.Add(pColHeader) Next
Then you can add the items and the subitems. The error you made is that you only filled in the items (these only fill the first column). To fill in the subsequent columns, you need to add subitems:
Dim pListItem As ListViewItem  pListItem = Me.Listsheet.Items.Add(pFeature.Value(0)) ' fill in value in first column For i = 1 To pFeature.Fields.FieldCount - 1     pListItem.SubItems.Add(pFeature.Value(i))         ' fill in values in all remaining columns     Next
I hope this helps.
Kind regards,
Barbara
BarbaraSchneider1
I hope this helps.
Kind regards,
Barbara
HushamHassan
hi Barbara
Thank you for your help Your code worked fine after little modification.
Here is the working Code for me.
Dim pColHeader As ColumnHeader
            Dim strFieldname As String
            For j = 0 To pFeature.Fields.FieldCount - 1
                strFieldname = pFeature.Fields.Field(j).Name
            Dim pListItem As New ListViewItem
            For i = 1 To (pFeature.Fields.FieldCount - 1)
                ' pListItem.SubItems.Add(CStr(pFeature.Value(i)))       ' fill in values in all remaining columns
                pListItem.Text = Convert.ToString(pFeature.Value(i))
                pListItem.SubItems.Add(Convert.ToString(pFeature.Value(i)))
Regards
