Arrow in LineSymbol WPF API
5707
04-16-2013 06:13 AM
foxfire
Help please. I'm using ArcGis WPF API for paint schemes on the map. I need to draw lines with arrows. Is this possible and how to do it? For drawing I use ESRI.ArcGIS.Client.Draw.
MichaelBranscomb
Esri Frequent Contributor
You could consider extending the Draw class - see this example: Custom Draw Tool
Cheers
Mike
BrianLocke
Pretty sure that I saw the new .net SDK come with an Arrow type?
JenniferNery
I'm not sure if you simply want to update symbol template to include an arrow or if you wanted an arrow shape.
For custom symbols, you can try this SDK sample: ArcGIS API for Silverlight - Interactive Samples | ArcGIS for Developers  or symbol gallery: ArcGIS API for Silverlight - Symbol Gallery. Basically, you will need a LineSymbol and define a Control Template that includes an Arrow Shape.
If you want an arrow shape, you can try this SDK sample: ArcGIS API for Silverlight - Interactive Samples | ArcGIS for Developers click on the button with "Add an arrow" tooltip and then mouse down + drag + up to create this shape.
By default, this creates a Polygon but you can subscribe to DrawComplete and convert to Polyline.
        void Button_Click(object sender, RoutedEventArgs e)
            var draw = new Draw(MyMap);
            draw.DrawMode = DrawMode.Arrow;
            draw.DrawComplete += draw_DrawComplete;
            draw.IsEnabled = true;
        void draw_DrawComplete(object sender, DrawEventArgs e)
           ((Draw)sender).DrawComplete -= draw_DrawComplete;
            var polygon = (Polygon)e.Geometry;
            var polyline = new Polyline() { SpatialReference = polygon.SpatialReference };
            foreach (var r in polygon.Rings)
                polyline.Paths.Add(r);
            var layer = MyMap.Layers["MyLayer"] as GraphicsLayer;
            layer.Graphics.Add(new Graphic() { Geometry = polyline, Symbol = new SimpleLineSymbol() });
