Add Layer (.LYR) failed
2342
04-15-2013 01:30 AM
Santosh_Pavan_KumarNukala
Namaste,
I am trying to create a layer and save it on a stand alone Engine based application in C#. I have created a graphics layer and tried putting some graphic elements on layer. I was able to save the Layer in .LYR format, I am able to successfully display the same when selected from Add Data button in toolbar. When I transfer the file over to another system over LAN and try to open the same layer on another machine, I am getting error message , "Adding the selected layer failed" and says the layer might have been created in older version as you can find in the attachment. I am using same version of ArcObjects 10.1 on both machines. Please let me know how I can display .LYR files on another machine, or is there something I have to do before transferring the layer file like Import/ export.
Please Help as I have got Stuck up at this point.
Thanks and Regards,
Pavan
nicogis
In these machines have you same config (x64 or x32, O.S., same service pack arcengine). Have you tried see version of layer saved (use IDocumentVersion)?
