Possible to use esri.dijit.PopupMobile as replacement for default InfoWindow?
4366
04-05-2013 05:12 AM
TomLougee
I'm developing a mobile app using ArcGIS JS API compact v3.4 and would like to use esri.dijit.PopupMobile as a replacement for esri.dijit.InfoWindow, as they both inherit from the same base class.
I'd like PopupMobile to be able to read and present attributes from graphics on a GraphicsLayer, via a custom InfoTemplate, like InfoWindow does. Ideally this would use the "click for more" arrow which PopupMobile offers. I'm not sure if there's a way to do this, though, as PopupMobile seems to require a FeatureLayer.
If I call
popup.setContent(content)
as I would with an InfoWindow, there's no error, but nothing seems to happen - PopupMobile appears with the correct title, but I don't get the right-hand "more" arrow as I'd expect (as shown in the attachment).
Adding a the graphic (which has the attributes) via
popup.setFeatures([graphic])
gets me the arrow but clicking it just hides the popup completely.
Is it possible use PopupMobile like the InfoWindow?
Thanks all!
KellyHutchins
Esri Notable Contributor
In order to see the content for the selected feature you'll need to use the setFeatures method to associate the feature with the popup. Here's a code sample that shows this approach:
<!DOCTYPE html>
<html>
<head>
  <title>Create a Map</title>
  <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9">
  <link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.4/js/dojo/dijit/themes/claro/claro.css">
  <link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.4/js/esri/css/esri.css">
  <style>
    html,body,#mapDiv,.map.container{
      padding:0;
      margin:0;
      height:100%;
  </style>
  <script src="http://serverapi.arcgisonline.com/jsapi/arcgis/3.4/"></script>
  <script>
    dojo.require("esri.map");
    dojo.require("esri.dijit.PopupMobile");
    dojo.require("esri.layers.FeatureLayer");
    var map;
    function init(){
      var popup = new esri.dijit.PopupMobile({}, dojo.create("div"));
       map = new esri.Map("mapDiv", {
        center: [-122.41, 37.77],
        infoWindow:popup,
        zoom: 14,
        basemap: "streets"
        var template = new esri.InfoTemplate();
        template.setContent(getTextContent);
        var featureLayer = new esri.layers.FeatureLayer("http://servicesbeta.esri.com/arcgis/rest/services/SanFrancisco/SFStreetTreesRendered/MapServer/0",{
          mode: esri.layers.FeatureLayer.MODE_SNAPSHOT,
          outFields: ["*"],
          infoTemplate:template
         dojo.connect(featureLayer, "onClick", function(evt){
           map.infoWindow.setFeatures([evt.graphic]);
        map.addLayer(featureLayer);
   function getTextContent(graphic) {
       var attr = graphic.attributes.qSpecies.replace('"',"").split("::");
       var content;
       var scientificName = attr[0];
       //display the common name if it exists - otherwise just the scientific
       if(attr[1]){
         content = "<b>" + dojo.string.trim(attr[1].replace('"',"")) + "</b><br/><i>" + scientificName + "</i>";
       } else {
         content = "<i>" + scientificName + "</i>"
       return  content + "<br>" + graphic.attributes.qAddress  + "<br/> Planted on " + formatDate(graphic.attributes.PlantDate);
      function formatDate(value){
        var inputDate = new Date(value);
        return dojo.date.locale.format(inputDate, {
          selector: 'date',
          datePattern: 'MMMM d, y'
    dojo.ready(init);
  </script>
</head>
<body class="claro">
  <div id="mapDiv"></div>
</body>
</html>
TomLougee
Thanks for your reply Kelly. I'll try this ASAP (been taken off onto other things for now!)
