Multivalue query
2284
6
03-26-2013 12:38 PM
TonyAlmeida
MVP Regular Contributor
I am trying to create a script that allow me to enter more then one value to search, select and create a new feature from the selected. My script runs and finished fine but produces no out feature class. I am not sure if i am doing it correctly or not but any help would be great.
Thanks.
import arcpy  arcpy.env.overwriteOutput = True mxd = arcpy.mapping.MapDocument("CURRENT") df = arcpy.mapping.ListDataFrames(mxd, "Layers")[0] lyr = arcpy.mapping.ListLayers(mxd, "Taxparcels")[0]  #Define input/output input = arcpy.GetParameterAsText(0) fieldName = arcpy.GetParameterAsText(1) values = arcpy.GetParameterAsText(2) output = arcpy.GetParameterAsText(3)  #Build the where clause queryJoin = "' OR " + fieldName + " = '" whereClause = fieldName + " = '" + queryJoin.join(values) + "'"  #Select(input, output, whereClause) arcpy.SelectLayerByAttribute_management(lyr, "NEW_SELECTION", whereClause) if int(arcpy.GetCount_management("Taxparcels").getOutput(0)) > 0:     arcpy.Select_analysis("Taxparcels", output)
Script parameters
are attached.
curtvprice
#Build the where clause whereClause = "{0} in ('{1}')".format(fieldName, "','".join(values.split(';')))
It's a little trickier than this because the each string value needs to be quoted.
#Build the where clause values = values.split(";")  # split values into list values = ["'{0}'".format(v) for v in values] # add single quotes whereClause = "{0} IN ({1})".format(fieldName, ",".join(values))
This will generate a string that would work as a SQL expression like:
FIELD1 IN ('R12351','R12352')
UPDATE: Mathew Coyle's solution also works. I didn't see that he was joining using the string "<single-quote><comma><single-quote>", ie "','".  Neat!
He's right: Potato, tomato. I just can't resist showing off that most awesome of Python constructs, the "list comprehension", sorry.
MathewCoyle
Honored Contributor
If you are only making selections from one field you can make a much easier query using the 'IN' command.
Instead of  this
query = 'field = x or field = y or field = z' #etc
It would be this
query = 'field in (x, y, z)'
You also don't need to run a separate selection when using the select tool, you can input the where clause directly in the tool.
The main issue you are probably having is your values variable is a string and you are trying to add it how generally lists are used. How do you plan on having your users input multiple values? You would need to post a sample of your valid field values and the actual properties of your values parameter to get more help.
TonyAlmeida
the values would be manually entered like this (R12351, R12352). I have attached a sample of the data.
Thank you for replying.
MathewCoyle
Honored Contributor
Something like this should work. Should be all you need after your inputs.
if int(arcpy.GetCount_management(lyr).getOutput(0)) > 0:
    arcpy.Select_analysis(lyr, output, whereClause)
curtvprice
MathewCoyle
Honored Contributor
It's my lazy way, but it still works. Though yours is more pythonic I would wager. Potato, tomato.
TonyAlmeida
Works great thank you to both of you!
