What do these Errors mean? when creating turn restrictions....
2026
03-14-2013 10:03 AM
JoyStraley
Been running into problems creating turn restrictions. Some turn restrictions are that are built into the network dataset are not being obeyed by the routes run during a Solve. Where turn restrictions need to be added edit session throws a multitude of errors. Is there an Network Analyst error data dictionary somehwere in resources? Are these errors a result of the Silverlight platform laying on top of our Network Analyst? Attached is documentation of what I have captured so far. Has anyone else had these problems when building a routing network?
Thanks, Joy
JaySandhu
The errors may indicate some problem with the basic feature geomery that is causing the turn editing to fail. Perhaps you can run the GP tools: Check Geometry and Repair Geometry to see if that will identify/fix such problems. Make sure to keep a copy of your data as you do these things.
Also, are you able to run build network successfully? If yes, take a look at the log files (they go to %TEMP% folder), namely Build.txt and BuildErrors.txt to see if any problems are being reported there.
Jay Sandhu
