Unable to re-install Operations Dashboard
4601
5
02-14-2013 10:19 PM
StephanKünster
Hi all,
after uninstalling the Operations Dashboard I'm unable to re-install it on the same machine.
I attached a screenshot of the error message.
Anyone else who's encountering that error?
Any suggestions how to solve it?
Cheers,
Stephan
DeniseKing
Stephan,
Esri Support has reproduced the error & notified Apps Group who are working to correct this as soon as possible. Thank you for bringing this to our attention. Please follow forums for updates.
Thank you,
Denise
DeniseKing
This has been resolved, the Operations Dashboard for ArcGIS install & upgrade is working.  🙂
Denise
StephanKünster
indeed, it is working! thank you.
WUTTIBOONFA-AMNUAYPOL
Hello , I still got the same problem after I tried to reinstall the operations Dashboard. I also rechecked that no current version installed anymore. Please suggest
ShannonPhilippus
Found that sometimes there is an issue with ClickOnce installations.  Delete the contents from this folder and reinstall:
C:\Users\username\AppData\Local\Apps\2.0 you should be good to go.
