Filter in ArcGIS Online
536
01-09-2013 11:13 AM
TorbjørnDalløkken
Hi!
I'm trying out the new filter-functionality in ArcGIS Online. I have a hosted feature service containing some objects and one of the attributes are a date. The datefield is in the format mm/dd/yyyy (month/day/year), but when I try to filter the objects based on this field every object disapears. I've tried using unique values in the filter dialog, but the year is missing. It shows the norwegian letters (abbreviation) for year "1/10/ååå", which is similar to "1/10/yyy". If I try to use this value, no features show up (displays).
Does anyone else experience this problem (probably not in Norwegian...), or is it just a bug in the norwegian version of ArcGIS Online?
MikeMinami
Esri Notable Contributor
what data did you use to create the feature service? the data needs to be in UTF-8 encoding. Here's a post that might help.
http://forums.arcgis.com/threads/71889-how-to-change-coding-in-arcgis-online?highlight=utf-8
thanks,
Mike
