Error message when I try to run basic viewer application
654
01-04-2013 09:42 AM
ErikBlake
Has anybody got this or seen this before (see attachment below)... If so what i am doing wrong. I made sure everything was entered correctly plus I have successfully opened other application templates before. is the basicviewer template that you download corrupted?
MikeMinami
Esri Notable Contributor
Is the web map shared appropriately?
Is the application published to ArcGIS.com or have you downloaded the template and deployed it to your own web server? If you downloaded it, you probably need to configure the proxy. See the readme instructions.
Mike
