how to put a random value to split component ?
816
12-19-2012 01:04 PM
anthonymagdelaine
now, my problem is to put a random value to a square and for each value, make a different action.... (actually just different color)
[ATTACH=CONFIG]20086[/ATTACH]
my random value is set (0,5) and as you can see, i thinking to use similar way as split.index, but it doesn't work.
dont know how i can make it
MatthiasBuehler1
Hi !
the split() operation automatically tries to even out the values.
If you want to split in different sized parts, I usually use a recursion :
minSize = 5
relativeValue = rand (0.2,0.8)
Rule -->
    case scope.sx > 2 * minSize :
        split(x) { 'relativeValue : Rule | 'relativeValue : Rule}
    else :
        Done.
[I did not test this example.]
Hope this helps !
