Problems with Euclidean-distance tool
5808
12-13-2012 07:23 AM
MarkusRasmusson1
I've run in to some problems when I've tried to use the euclidean-distance tool. As you can see on the picture the results comes in the form of a "box", it almos looks like the analys just stopped in the middle. In the euclidian distance dialog window I select the raster-layer that I want to use, specify the output cell size to 50 and click ok. I don't set any maximum distance since I want all cells to be taken into consideration. Have anyone got an idea what I'm doing wrong?
[ATTACH=CONFIG]19908[/ATTACH]
DanPatterson_Retired
Did you set the analysis extent in the Environments button in the Euclidean Tool?  If not, do so.
MarkusRasmusson1
Thank you, Dan! It seems like that was the problem, now it works.
