determining maximum cell from a Numpy array
2684
6
12-06-2012 11:12 PM
BarbaraLokes
hello
i have a large numpy array and i would like to write a python script for assigning zero (0) to every maximum cell in every four adjacent cells. For example, see figure below:
[ATTACH=CONFIG]19775[/ATTACH]
Any help would be very much appreciated, thanks in advance!
AndrewChapkowski
You can find a value positions by doing the following:
   itemindex=numpy.where(array==item)
Then change your values.
You can find the max value by doing the following:
>>> from numpy import *
>>> a = array([10,20,30])
>>> a.max()
30
>>> a = array([[10,50,30],[60,20,40]])
>>> a.max()
60
Hope this helps.  You can find more information about numpy by going to the scipy.org site.
RaphaelR
tried this with a sample 6x6 grid. i´d really like to know if there´s a better way (i´m sure there is) using more numpy/scipy (tried that at first but couldn´t really get it working).
anyways...
in:
[[  5.4   7.5   2.2   8.5   8.6   7.5]
 [  7.7   3.5   1.4   9.6   8.5   5.5]
 [  5.2   6.1   8.6   6.7   4.3   6.8]
 [  9.3   4.5   2.7   3.6   6.7   4.5]
 [  1.2   2.3   7.2   6.3   2.2   2. ]
 [  1.3   2.  -99.    4.  -99.    1.2]]
nrows=6
ncols=6
for row in range(0, nrows -1, 1):
    for col in range(0, ncols -1, 1):
        # current 2x2 subgrid
        curgrid = {grid[row,col]:(row,col), grid[row, col+1]:(row, col+1),\
                   grid[row+1,col]:(row+1,col), grid[row+1, col+1]:(row+1, col+1)}
        # set max of current subgrid in the totalgrid to 0
        grid[curgrid[max(curgrid)]] = 0
out:
[[  5.4   0.    2.2   8.5   0.    7.5]
 [  0.    3.5   1.4   0.    0.    5.5]
 [  5.2   0.    0.    0.    0.    0. ]
 [  0.    0.    2.7   0.    0.    0. ]
 [  1.2   0.    0.    0.    0.    0. ]
 [  1.3   0.  -99.    0.  -99.    0. ]]
AndrewChapkowski
Your list syntax is incorrect.  You need to use commas between values.
You can find out about type formatting at python.org.
Andrew
RaphaelR
the input is an array
print type(grid)
<type 'numpy.ndarray'>
AndrewChapkowski
Try putting commas after each number.
My code worked then.
RaphaelR
the code works for me as well.
i just said that i would also be very interested in a more/only numpy-based approach.
