Integrate unique shape
1842
12-05-2012 04:18 AM
TadeoSanabria2
Hello
Try to model the regulations of the urban plan of a city, but I have two problems:
1. delimit public transfers  of urbanization, if I use the rule:
Cession ->
s (side of the rectangle, 0, side of the rectangle)
Not how to become a complement to correspond to the footprint. I think it could subtract the original scaling the result of the rule, but not how.
Any idea?
2. if I use the rule:
Cession ->
setback (sideCession) {back = Lot | left = Lot | remainder: CessionEP}
CessionEP ->
extrude (1) color ("# 80FF00")
Lot ->
color ("# 80FFFF")
setback (AislamientoPosterior) {back: Post | remainder: Cuerpo0}
In this case I can´t integrate the lot in a single form. There are some instruction that allows me to do this?
Thanks. Insert Image
[ATTACH=CONFIG]19710[/ATTACH]
MatthiasBuehler1
Hi !
Sadly, you can not split and the rejoin the resulting shapes yet in CE.
So you'll have to find a proper series of splits which results in the geometries you'd like.
This can indeed be tricky to code, I'm currently thinking about parcel subdivision in CGA a lot too !
Try working with setback(), shapeL() shapeO() shapeU() and split(), together with different aligns.
Let me know if you're stuck somewhere !
m.
TadeoSanabria2
Thanks matthias
I Tryed to set the new geometry and follow your recommendations. excuse my bad English
can I use Boolean operations with shapes ?
eg intersection, union, subtraction. through which instruction?
Tadeo
MatthiasBuehler1
Hi !
Sadly, also no booleans available. You really have to split the geometries in the order you need them.
Of course it can be that some things are not possible.
It' d be best you post a quick drawing of what the input geometry is and what your target geometry is. Then I may have some inputs for you.
M.
