Customize Date Picker for Python Toolbox Parameters
5641
11-19-2012 11:24 AM
MichaelMarkieta
Hi all,
I have a Python Toolbox that converts a file geodatabase table to a format useful in external analysis. However, I would like to be able to export a subset of data by selecting a specific date on a calendar.
What I have now is a date selection calendar that I can use to select the appropriate date. What I would like is for the calendar to only make available to me the dates that are available in the param0 "DATE" column. See example code and screenshot below.
def getParameterInfo(self):
    param0 = arcpy.Parameter(displayName="Input Table",
                             name="in_table",
                             datatype="Table",
                             parameterType="Required",
                             direction="Input")
    param1 = arcpy.Parameter(displayName="Input Date",
                             name="in_date",
                             datatype="Date",
                             direction="Input")
As you can see, there is only data available for 1/3/2012. I would like all calendar dates to be suppressed except for the those dates in the param0 "DATE" column.
[ATTACH=CONFIG]19403[/ATTACH]
MattSayler__Work_
I like the idea. Will be interesting to see if they have the date picker exposed (haven't seen anything in documentation that indicates it is, but who knows?).
curtvprice
Seems to me the best approach would  be to treat the date as a string and in the validation code read the date values out of the file, unique and sort them, and populate a pick list (filter property) of strings for the user to choose from. This would probably be easier to navigate than the calendar widget anyway.
ThomMackey
Do you have this operating now? That would be really useful for a tool I'm working on, too. Would you mind sharing how you did it?
Edit: Hahaha, I never even noticed there was a "Date" parameter type that provided a date picker! That's super useful! Just when you start to think you've got this ArcMap thing under control...
DPolis
Is there a way to limit the Date date type to Date only ie limit the Calendar date format radial buttons?
