Iterate Feature Selection equivalent in Python
1932
11-14-2012 11:03 AM
MargretAdaya
I made a tool in Model Builder that uses "Iterate Feature Selection" and I'm trying to figure out if there is an equivalent I can use in Python.
Basically, the tool goes through each feature in my "Subdivision_Copy" feature class and groups by the field "Community" and exports each feature as a shapefile in a "Scratch_Shapefiles" folder.
[ATTACH=CONFIG]19296[/ATTACH]
I'm still learning Python and I'm not too sure how to go about doing this.
Thanks for any help!
curtvprice
Have you considered setting up your model as a script tool (with parameters), importing the toolbox using arcpy.ImportToolbox, and running the model from your Python script? If you're more comfortable with ModelBuilder - why not let it do the tricky stuff?
arcpy.ImportToolbox("Mytools.tbx","Model1")
arcpy.MyModel_mytools(input,output)
The code to do this in Python would be complicated enough (especially if you are using several group by fields) that this may be a good approach for you.
You could use the output of the Collect Values tool as an output parameter to pass the list of output datasets back to your python script.
MargretAdaya
Thanks for your reply! I'll try it out!
