Search Widget Sort Results
1399
11-02-2016 01:25 PM
ImranMohammad
I am trying to display my search results in the ESRI's WAB widget. I am able to configure it to retrieve the data in a list format but i am not able to sort the display of the dropdown to show in an alphabetical sort order does anyone have any suggestions? (Please refer to the screenshot attached.) Thank you for your time and help.
RobertScheitlin__GISP
Imran,
   There is not property or configuration to sort the search widgets suggestion results.
RodWoodfordOld
Occasional Contributor III
Hopefully ESRI add some configuration parameters for this.
cheers
Rod
RachelAlbritton
Robert - Is this true for the Javascript 3.17 version of the search widget as well? There doesn't seem to be any logic as to how the search suggestions are sorted.
Yes, There no sort ability for suggestions even in 3.20
