my location widget scale problem
5512
16
02-03-2016 07:08 AM
MathiasEriksson
I have a my location widget that has the code.
  "locateButton": {
    "geolocationOptions": {
      "timeout": 15000
    "highlightLocation": true,
    "useTracking": true,
    "scale": 1200
the scale command give a perfect scale.
but if I zoom in or out it resets after 15 sekund. ( I can change reset time to what ever I want)
I'm trying to get it to stay at the zoom lvl  the user sets after first positioning.
If i remove scale is goes to maz zoom every 15 seconds
I have try to use :
  "locateButton": {
      "timeout": 15000,
      "setScale": false
    "useTracking": true
but the it zooms in to max and stay the. I can't zoom out.
any one have a any good input on this?
RobertScheitlin__GISP
Mathias,
   Looks like you are missing the nls folder or just the strings.js file in that folder from your my location widget. That is the most serious issue. Next I am not good at minified code editing but the change I would suggest is:
this.geoLocate.setScale = !1;
EDIT: I made a correction to my earlier code and tested this on a minified WAB App I downloaded from AGOL and it worked for me.
Mathias Eriksson
See my above edit and info about missing file.
MathiasEriksson
So the correct code should be somthing like this :
onLocate: function(e) {
            d.removeClass(this.placehoder, "locating");
            this.geoLocate.useTracking && d.addClass(this.placehoder, "tracking");
            e.error ? console.error(e.error) : (d.addClass(this.domNode, "onCenter"), this.neverLocate = !1)}
IS tha correct ?
I'm reinstalling my webserver but will try this in a few hours.
Correct
MathiasEriksson
should I still have scale command in config_my Location.json
I still only get to the loading screen. and the widget donät show up.
Yes you should have the scale set in the config_my Location.json.
When I look at your site: http://app.sandbyborg.se/widgets/MyLocation/Widget.js  I do not see the change to the onLocate function included.
MathiasEriksson
not uploaded to that site yet.
