I am using Web AppBuilder 2.0 with the LocalLayer Widget 1.3.1.
I have two sub-layers (both dynamic). I configure pop-up and choose custom.
For the first sub-layer (Valves) I enter this:
<b>Diameter:</b> {DIAMETER}
<b>Type:</b> {VALVE_TYPE}
<b>Location:</b> {LOCATION}
<b>Purpose:</b> {PURPOSE}
<b>How is Valve Operated?</b> {OPERATOR_TYPE}
<b>Number of Turns:</b> {TURNS}
<b>What is the Normal Valve Position, Open or Closed?</b> {VALVE_POSITION}
For the second sub-layer (Pipes) I enter this:
<b>Map Label:</b> {ANNOTATION}
<b>Process Stream:</b> {PROCESS STREAM}
I clear my cache (using Firefox). I save. I launch. I click on valves and pipes. You will see that the pop-up for valves is populated with the attributes. You will see that the pop-up for pipes is empty of attributes.
I double checked the attribute table and key values for both. They match exactly.
Any ideas on why the pop-up is normal for the first sub-layer and not the second?
See attached for screenshots of what I am seeing.
