How to use spatial filters ?
2657
8
08-13-2018 02:03 AM
SaraEL_MALKI
Occasional Contributor II
Hi guys,
I am new to WAB, and tring to discover it
I have poped into the spatial filters, but something sounds missing for me !
look at the image:
It shows that you will get only the features that are intersecting with the layer that you choose,
BUT I want to get only that results that intersect with ONE ELEMENT in that feature layer, as example
I want to get all the supermarkets (supposing I have a feature layer called suppermarkets) (apply on them a query) and from the result of this query I want to get ONLY the elements that intersect a city called Barcelona (supposing I have a feature layer called cities)
any help please ?
ArcGIS Online Team
XanderBakker
Esri Esteemed Contributor
Not sure if this would work, but if you apply a filter to the cities first selecting/showing only Barcelona, and then perform the intersect with the supermarkets, would that yield the result?
RobertScheitlin__GISP
Another option is to use the custom eSearch widget. Doing a query for a city first and then switching to the by Spatial tab and and choosing intersects.
SarrahEL_MALKI
Where I can find the custom eSearch widget ?
You can search for the eSearch and many other custom widget in this WAB custom widgets space that you are posting in right now.
https://community.esri.com/docs/DOC-1731-enhanced-search-widget-version-211-080116
SaraEL_MALKI
Thanks for the link,
but excuse my bad knowledge, can I create my own custom widgets and add them to my Portal without having to host the application on my web server ?
becaue I know there is a possibility to download the application, edit it and host it on my localhost, but I need to keep it hosted on Portal but at the same time have the ability to add custom widgets !
any links ?
Sara,
   If you have an on-premise Portal (not AGOL) then yes you can use custom widgets and not have to host the app locally.
SaraEL_MALKI
Actually I was happy with your last answer because it would be easy for me, then I searched a liitle bit on the forum and found a contradiction between your suggestion and Mr. Derek Law answer on that post:
https://community.esri.com/thread/121410
