How to remove a layer from the Legend widget in Developer Addition Web App Builder? We are programmatically adding a Grid layer to the map using JavaScript API, not the Web Map, and would like to hide the layer from the Legend Widget when we add this lay
2598
6
10-25-2017 10:37 AM
CenterlineMapping
New Contributor III
How to remove a layer from the Legend widget in Developer Addition Web App Builder? We are programmatically adding a Grid layer to the map using JavaScript API, not the Web Map, and would like to hide the layer from the Legend Widget when we add this layer to the map.
This is how we add the layer to the map in the application:
var grid = new ArcGISDynamicMapServiceLayer("<mapserver>", {
          "opacity" : 1.0,
          "imageParameters" : imageParameters
        this.map.addLayer(grid);
        grid.setVisibility(false);
Upon clicking a checkbox, the layer is set to visible = true.  We would like for this layer not to be added to the Legend widget as it is a simple 1 x 1 grid of the globe.
Thank you for your time.
RobertScheitlin__GISP
In the Legend Widget.js make these changes (lines 23 - 32, of corse changing Highway - ABIMS Bridges to your layers name as it appears in the legend):
    _getLayerInfosParam: function() {
      var layerInfosParam;
      this.config.legend.layerInfos = [{
        hideLayers: []
        hideLayers: []
        hideLayers: [0, 1]
      if(this.config.legend.layerInfos === undefined) {
        // widget has not been configed.
        layerInfosParam = legendUtils.getLayerInfosParam();
      } else {
        // widget has been configed, respect config.
        layerInfosParam = legendUtils.getLayerInfosParamByConfig(this.config.legend);
      filteredLayerInfosParam = layerInfosParam.filter(function(layerInfoParam) {
        if(layerInfoParam.title !== "Highway - ABIMS Bridges"){
          return layerInfoParam;
      return filteredLayerInfosParam;
      // filter layerInfosParam
      //return this._filterLayerInfsParam(layerInfosParam);
      //return layerInfosParam;
        hideLayers: []
        hideLayers: []
        hideLayers: [0, 1]
      } else {
CenterlineMapping
New Contributor III
Thanks Robert that worked like a charm.  You are the man.
Great,  Don't forget to mark this question as answered then.
CenterlineMapping
New Contributor III
Done
Mehretab
Occasional Contributor II
hi Robert is it also possible to hide only a sub-layers in a ArcGISDynaicMapserviceLayer ? It seems the layerInfoParam object returns,
{hideLayers: Array[0], layer: Object {...}, title: "Bird_Area"}
but the script to hide the sublayers seems not to work.
layerInfoParam.hideLayers[0];
thanks,
Mehretab
Got it working for the sub layers. here is the working code for anybody looking to hide a specific layer in a dynamic services
if(layerInfoParam.title === "Drinking_Water"){
//WORNG WAY TO ACCESS THE LAYRS THIS WAS MY MISTAKE
//layerInfoParam.hideLayers[1];
//THE RIGHT WAY TO ACCESS THE SUBLAYERS IN DynamicMapService
layerInfoParam.hideLayers=[0,1];
// return layerInfoParam.layer.layerInfos[0];
Thanks again Robert for all the hard work.
