I am using the LaunchPad Developer Edition to develop an app, I would like to create a folder icon, and click on it, it can pop up several different widgets, then I can select on it and open each one I want as following pic:
Is there any method I can realize this effect? Thanks!
Jake,
OK that is what it currently does when you create a widget group, so your question must be how to create a widget group.
Here is the help link for that:
Widget Group—Web AppBuilder for ArcGIS (Developer Edition) | ArcGIS for Developers
Jake,
You mention
What do you mean by this? The icon would have a click event that would open the popup that shows the folders widgets.
Or are you just asking HOW to create a widget group?
I mean click on the folder icon, it display/pop up 2 widget icons (widget A and widget B), then click on one of them, it can open one widget at one time. Thanks a lot!
Jake,
Thank you very much! I have marked the reply as correct answer.
