Hello,
I am new to WAB and I would like to know if there is a widget that allows a feature hover that allows the user to see a a feature highlighted when hovering over a feature with the mouse.
For example: A world map and when a user hovers over a country, the entire boundary is highlighted and/or outlined.
Any help is greatly appreciated!
Solved! Go to Solution.
I have installed the FLHover and it is awesome. It works great in WAB dev however i try to add it to my portal as a custom widget and it doesn't work. I am using my web server to host my widgets so they are not on my portal server. Do you think this could be the issue? Are there certain methods that need to be installed on my web server? Thanks for your help.
What version of Portal are you running?
10.6.1
I updated the wabVersion to my version
It does work to just add it in Web App Dev and take the whole app and put it on my web server. I don't know why i didn't think of that.
BTW I always look for your blogs and tools they are always terrific! Thank you so much for all you have contributed to GIS.
