Jeremie Cornet I created a blank new app in WAB12 (Default theme all defaults). Added new eDraw 1.3.3 10/22. After adding a Text, the Point doesn't work. Actually clicking it brings up the Draw tab in fact.
ArcGIS Web Application
So, then I just took an existing demo site (a test site built with WAB 1.2 to show my Query), then I duplicated it and changed the folder name on my server. So, a complete WAB site. Then, I deleted the eDraw widget folder (which was your pre-release eDraw 1.3.3 version you asked us to try earlier in the thread..I'll call it September 1.3.3 eDraw..) I then copied in your new eDraw 1.3.3 10/22. And... it seems to work! Just fine.
I even copied the new config.json from this one that works, to the first one above, and it still didn't fix it.
So... I guess for now, I'll just manually copy in your eDraw to new WAB sites I build, after I download it out of WebApp Builder. It's probably not your code, given all this. Something's probably gotten messed up in my WAB. Anyway, since no one else sees it, and I can fix it with this workaround for now, I will assume it's my WAB or something specific to my settings with eDraw and not worry about it or test it further, unless you would like me to do something specific. Maybe I will build a completely fresh WAB folder, the next time ESRI updates (1.3).
update: Actually this is a problem. The real site I am building is internal. Just copying fresh 1.3.3. eDraw in didn't change anything. I noticed a difference. For the site that eDraw works, it has a eDraw folder in the site "configs" folder. I.e. if the site is named MySite it's MySite/configs/eDraw/config_Draw.json However removing that file breaks the widget it won't initialize. But the weird thing is, the site where eDraw works doesn't have the file or folder in Configs. And yet.. it works just fine. Sorry if this is confusing. I will try to figure it out.
