If you check out that link you will be directed to a map. If you hover over a section of the map, you will see a highlight along the elevation for that path. Does anyone know of anything like this in an ESRI widget? This is pretty cool stuff.
Solved! Go to Solution.
Brian,
Are you thinking something like this?
Esri/elevation-profile-template · GitHub
Robert Scheitlin, GISP already has a widget out that does most of this. The only thing is that it does not work on pre-defined lines. Elevation Profile Widget Version 1.1.2 - 3/27/2015
You can look here for all widgets made by users Web AppBuilder Developer Edition – Customization Resource List
And here for all of esri out of box widgets. Esri/solutions-webappbuilder-widgets · GitHub
Brian,
Deepti,
I am not sure if it does for portal. You can always set up your own gp service and publish it on your own server.
