Wrap a custom widget created by the WebApp Builder to a javascript API module
2007
06-02-2020 07:54 AM
YanivLev
Hello all,
I went thru the documentation but I'm pretty new to ESRI and WebApp Builder so not sure if what I'm asking is possible...
Lets say I've created a custom widget using the WebApp Builder (my own template and functionality in its "widget.js" file and so on) - is it possible to wrap it up as an API and consume/require it like esri's other widgets (like "esri/widgets/Expand")?
require([
     "esri/WebScene",
     "esri/views/SceneView",
 ], function(
     WebScene,
     SceneView,
     Expand
My goal is to create a custom widget using WebApp Builder - but later on to use this widget thru API and not the builder itself.
Is that possible?
Thanks.
RobertScheitlin__GISP
Yaniv,
   No that is not an option. WAB widgets have a lot of dependency on the jimu.js library and the whole WAB app structure.
Yaniv,
Egge-Jan_Pollé
Hi Yaniv Lev,
It is possible to create your own custom widgets for use in the JS API: Widget development | ArcGIS API for JavaScript 4.15
The ArcGIS for JavaScript API provides a set of ready-to-use widgets. Beginning with version 4.2, it also provides a foundation for you to create custom widgets.
HTH,
Egge-Jan
