Widgets that are labeled
1416
08-31-2021 10:39 AM
SWilander
How do I add text or labels to widgets? Are there many ways to do this?
I need to have widgets that are labeled, explaining what the widget is. EXAMPLE the "Layer" widget needs to have the text "Layers" directly beneath the 'layers' icon. Like the image I included.
FYI: If I change the Widget Icon to the example I have here (The Layers Icon with the text) the resolution is far too low to read the widget.
Tags (1)
CourtneyMenikheim
If you use a SVG icon for the widget, it will be more readable than a PNG.
Does the widget icon need to have a label always visible, or could you display the widget name when the user hovers the mouse over the icon?
Courtney Menikheim
SWilander
Thanks. OK on the SVG, -adobe here I come. I know I saw a pixel Width by Height somewhere in esri docs but failed to find that again. The default in the app has a text display on hover, but I have a wide range of users that refuse to see the 'hover' as a solution'.  Lets face it, I cant expect users to hover over every -low contrast item on the page, and or read the Splash Screen for usage guidance. If it takes 2 seconds, they want it 'easier to use'.
I think knowing more than one solution is good. The other is to get the Java script edited properly and complete the task in esri 'Web Appdeveloper' but I saw folks having trouble with that as well.
