Widget to modify Feature Service Symbology?
3931
08-06-2015 12:17 PM
JamesCrandall
A feature service that is loaded into a web map can be re-symbolized by the user.  Are there any widgets that perform this capability?
James
RobertScheitlin__GISP
James,
   I have not seen one yet. It would not be difficult if the Server is 10.1 or greater and the layer has Supports Dynamic Layers: true, so that you can use the esri/layers/LayerDrawingOptions. I guess the real issue is the amount of work to develop the UI that would support all the different renderer type and options. Hmm. now that I think about it, it would be a fairly complicated development task.
James,
JamesCrandall
Thank you for the reply, Robert.
