widget action sometimes does not trigger for supported features
4084
15
07-18-2017 01:16 PM
StahlyEngineering
I've created a custom widget that should execute a feature action for a specific feature class, checked for by the display field name.
When the widget is first added to a web app, everything works well. However if the app is saved and reloaded the feature action does not come up.
Are there specific locations where I should look for mismatched file names or something similar?
The browser (up to date Chrome) console does not report of any errors when attempting to add the widget to an app or selecting the target feature class.
(edit):
Doing any changes to the feature action .js file, including changing a comment or whitespace, saving the file and reloading the app allows the widget to work as intended until the app is reloaded again.
Thanks!
StahlyEngineering
No, the js file name is TSRecordsAction.
here's the relevant chunk of the manifest file:
"featureActions": [{
"name": "TSRecords",
"uri": "TSRecordsAction"
RobertScheitlin__GISP
Try changing them to be identical.
StahlyEngineering
I've done so and that does not seem to make a difference
What does your TSRecordsAction.js look like?
StahlyEngineering
define([
   "dojo/_base/declare",
   "jimu/BaseFeatureAction",
   "jimu/WidgetManager",
   "esri/tasks/FeatureSet"
],    function(declare, BaseFeatureAction, WidgetManager, FeatureSet){
   var stuff = declare(BaseFeatureAction, {
      iconFormat: 'png',
      isFeatureSupported: function(featureSet){
      return featureSet.displayFieldName == 'SRVNAME'; //test feature for action validity
   onExecute: function(featureSet){
      WidgetManager.getInstance().triggerWidgetOpen(this.widgetId)
      .then(function(myWidget){
/*=========== WIDGET ACTION ===========*/
         var twnshp = featureSet.features[0].attributes.TWNSHPLAB;
         var TS = twnshp[0] + twnshp[1];
         var RG = twnshp[4] + twnshp[5];
         myWidget.TSRecordsAction(twnshp,TS,RG);
return stuff;
Stahly,
   I don't see anything wrong there. Not sure what to tell you...
