where do i install enhance popup panel files
1595
05-01-2017 01:15 PM
devarsimajumder2
For the popup panel widget where do i install the files after i unzip it? Which folder within the main wab 2.2 folder do I add these files to? Thank you.   rscheitlin
RobertScheitlin__GISP
Devarsi,
   This widget is no different then other custom widget. You just add the PopupPanel folder to your stemapp/widgets folder and then re-start WAB and it will be in your widget choice list.
devarsimajumder2
hi robert
i installed the files  like you said in the correct folder but when i go to configure the widget it doesnt give me any options. shown below in image. I am  using version 2.2.  Is there  a previous earlier version i need for popup widget that will work with 2.2. I need some additional help. Thanks
Those are the only widget configuration options. The widget will just display the popup info for what ever popup info has been defined for layers in the web map and instead of being in a popup on the map it is in the popup panel instead.
