What widget do you want most
107183
221
08-05-2014 05:45 AM
RobertScheitlin__GISP
I have been working on a few custom widgets for the Web App Builder, but I would like some input as to what widget/functionality people are wanting most.
The WAB has several great OTB widgets but what (realistic) widgets are missing and would be (in your opinion) great to have?
BrianOevermann
Robert,
Thanks for the comment regarding printing with WAB. And sorry for the minor thread hijack...
JohnRogers1
Batch geocoding widget
by Anonymous User
Not applicable
1. An improved printing widget would be greatly appreciated.
2. A layer list with the ability to group layers as well.
BrennaSterling
Need a widget that allows user to select a parcel and then buffer it a specified distance and then export the corresponding selected attributes to a csv or txt or some like format?  Our planners need this to generate address labels for land use notifications.
The eSearch fits that bill perfectly.
BrennaSterling
Thank you I will check it out!
NolanAlbarelli
I would love to see two widgets:
A widget that shows GIS data in ur WWROOT folder.  So for example, If I drop a folder (with a shapefile, or GBD) into a specific folder, you can access it in the app.
Also, a better "Add Data" widget.  One that supports the adding of REST endpoints, Shapefiles, and GDB's. (with option to add layer to your layer list)
AdamDrackley
This would effectively replace ArcGIS Desktop and ArcGIS Server with a web app, which is a scary thought.  Any javascript gurus know how to crack open and view/edit a GDB?
LeoLadefian5
There is an add shapefile widget already out there if you do a search, and it seems the new version of WAB 2.1 has an add data button.  Isn't an SDE feature service the same thing as editing a GDB?
NolanAlbarelli
After reviewing some other input, I would agree on an "Enhanced Layer List" widget.  One that supports groupings of layers by tabs or some other clever way.
