WEB Directions widget - Customize the stop name on the search form
1319
05-17-2019 12:20 PM
MrRock
I'm a newbie to ESRI Api Javascript and WAB. So I have been trying to put a textfield as  a label(alias) beside each stop field on the search form instead of using automatically generated numbers like 1, 2, 3... Users should be able to customize the stop name. It will be similar to the widget Route on the Flex version. Could anybody tell how to do that? I just attached an image showing a draft.
VictorTey
Hi, Are you referring to a feature action?
https://developers.arcgis.com/web-appbuilder/sample-code/create-a-feature-action-in-your-widget.htm
The action can link to a form for the user to customize the stop name.
Alternative
https://developers.arcgis.com/javascript/latest/sample-code/sandbox/index.html?sample=popup-actions
and you can put forms in the content
var template = {
// autocasts as new PopupTemplate()
title: "Trail run",
content: "{name} <input type='text' name='firstname' value='whatever'>",
actions: [measureThisAction]
