web appbuilder
4033
10
10-13-2017 01:41 PM
MonaBrisco
Hello All,
I am trying to get a custom widget(CW) to work that uses a map click event.  The widget works as standalone but if also using the OOTB measurement widget(MW) I get weird behavior.  If I use the OOTB MW before I use the CW then I get expected behavior for both tools.  However, if I use the CW followed by the MW, when I close the CW the symbol it uses is cleared from the map but when using the MW the symbol replaces esri greenpin, the line segments disappear on dbl-clicks, and when MW is closed, the CW symbol remains.  Any ideas on how to resolve other than re-implement the OOTB MW(and I did not want to edit the OOTB MW code)?  I thought by using onClose() in CW to remove graphic/clear
map would resolve since graphic was removed(but looks like both widgets are bound to event).
Thanks in advance,
Mona
FranciscoCaldeira
Thanks Robert, I have spent two days on this issue!
