Web App Builder reporting widget
40725
41
03-31-2015 03:41 AM
MohammedMogahed
I need to create a widget in webappBuilder, to generate a report, that will contain map with its graphical layer, charts, and table.
Is there a widget that does this task, can I use the print widget, customize it and generate output that have this kind of report?
Mohammed Mogahed
BPriyaK
Hello Derek,
I've read through the blog ,but curios to know how can you add a dynamic table to the layout based on the selection of records  from the select widget to appear in your report
Any idea how this can be done ?
BPriyaK
Hello Derek,
DerekLaw
Esri Esteemed Contributor
Hi BPriya,
As I've stated earlier in the thread, sorry but I am not a developer - you may want to post a new question in this forum
Web AppBuilder Custom Widgets
Hope this helps,
SibghatUllah
I am also looking for some sample report widget .By viewing all the replies i think the best solution is to make  GP service.
SandiMcDaniel1
This post is NOT meant as a sales - I'm only trying to post it for informational purposes.  We've created a Reporting Widget using Web AppBuilder.  For information on the widget, please see: ArcGIS Online / Web AppBuilder Custom Widgets — Vestra
Sorry if I'm breaking the rules since we do charge for the widgets we've built...
DerekLaw
FYI everyone,
Nikki Golding‌ just posted a comment on the Report Widget idea thread,
Web AppBuilder Reporting Widget
The Solutions team recently released a configurable AWAB widget that supports reporting as part of the workflow.
Hope this helps,
DerekLaw
FYI,
A blog on the new 'Screening widget' developed by the Solutions team has been published,
An Introduction to Environmental Screening | ArcGIS Blog
Hope this helps,
HillaryBjorstrom
Hi Derek, The widget is a close to perfect fit for what I am looking for. I am very new at writing code with the API classes. Can you point me in a direction to find a code snippet that will pull in data from my current map instead of passing thru predetermined data? Thanks!
DerekLaw
Hi Hillary
Hope this helps,
BryanAustin
This would be a very useful.
