web app builder pop up with user input textbox
2052
10-28-2018 03:29 AM
CarolineBettach
Hello,
I'm new using web app builder.
I would like to enable the user to draw points and lines on the map.
When the user click on a point or on a line a pop up will be display and the user will insert details in textboxes .The point details and line details will be saved in the table.
How can i do that?
Thank you for your help,
CarolineBettach
Hello, thank you for your help!
Is it possible to save  the coordinates and info of the points that the user draw in a layer table and not in a json file (as the sample you sent me)?
Thanks a lot
Best regards,
RobertScheitlin__GISP
What you are wanting sounds more like you need to publish a Feature Service on AGOL or on your own ArcGIS Server. Then use the edit widget.
