Web App Builder Attribute Widget
4298
12
01-16-2019 08:43 AM
GeorgeKatsambas
I have a web map which is deployed to my arcGIS Server. Some of my map services are pointing to data that resides on SDE, Oracle 12g. When I open the Attribute Widget and try to do a statistics on a field I get this  error message. Now the map services were published from layer files I created , will this cause this error and I am using Web Builder 2.10
GeorgeKatsambas
However, I'm curious why statistics in the attribute table work in this web map?
RobertScheitlin__GISP
George,
  I need you to fix the woff errors before we can continue as they are obscuring the other issue.
GeorgeKatsambas
It seems that if " Filter by Map Extent" is on then this error occurs.
