Web App Builder Attribute Widget
4289
12
01-16-2019 08:43 AM
GeorgeKatsambas
I have a web map which is deployed to my arcGIS Server. Some of my map services are pointing to data that resides on SDE, Oracle 12g. When I open the Attribute Widget and try to do a statistics on a field I get this  error message. Now the map services were published from layer files I created , will this cause this error and I am using Web Builder 2.10
RobertScheitlin__GISP
George,
  OK you need to follow the link I provided in the beginning and get rid of those woff error first.
George,
   I do not know why you are getting the undefined for the statistics, But the errors you have in the console are to do with your web server not haveing the woff and woff2 MIME types registered.
Set mime types for web fonts in IIS » Coding Still
GeorgeKatsambas
Thanks Robert, the mime types I can live without, its the statistics in the attribute that I cant.
George so there are no other errors in the console beside the mime types?
GeorgeKatsambas
And These, i snipped 1/2 the console, oops
George,
  The last error listed there is the important one then. Expand that error and post again.
GeorgeKatsambas
Thanks Robert
George,
  No that is a warning. The error I want to see is in red right above that.
GeorgeKatsambas
If I expand the highlighted its pages and pages
and here is a bit of those pages.
George,
