WAB: How do I edit the group widget layout?
5282
32
09-07-2017 01:09 PM
FrancescoTonini2
Occasional Contributor II
I am using WAB Dev Edition 2.5 and am interested in customizing the behavior of the layout for the group widget. As of right now, when grouped together, widgets of the same group are automatically arranged like this:
I would like to customize the layout and behavior of the group widget so that, for example, each sub-widget is collapsed automatically unless the user click on the + sign. Or I would like to have a browser similar to the GPServiceBrowser Dijit where the user clicks on each widgets and it shows the content.
Any suggestions on where I should look to use the WAB JS API and its Dijits to manipulate and customize the group widget behavior? I know the main JS API developer page, but I am not sure where to look for the group widget specifically and whether WAB jimu offers any of what I am looking for...
by Anonymous User
Not applicable
Robert Scheitlin, GISP Thank you for your help! Quick question, is there a way to make the panel pop and be movable?
RobertScheitlin__GISP
No a grouped widget can not do that.
by Anonymous User
Not applicable
Thank you very much for the quick response!
