WAB: Change link text with custom widget
4105
10
07-02-2019 01:03 PM
KarstenRank
I'm developing a widget that checks a webhook payload if the map has been updated.
https://community.esri.com/thread/236190-re-popup-alert-when-webmap-has-a-new-save-date
If the payload timestamp is newer then the widget timestamp created at startup a popup window appears.
web mapping application
How can I additionally add something like "status of app" with my widget at the time the popup occurs?
Thanks for your help!
Karsten
Victor Tey Thank you for your tip!
VictorTey
Hi Karsten, I have not had the opportunity to look at the DOM in depth but you can basically use dojo query(similar to jquery) to retrieve any DOM by css or by ID. Look for a unique attribute in the DOM and modify the content. Hope that helps
