Url Query (urlToObject)
7290
08-22-2014 06:09 AM
JonathanPascoe
I'm trying to add a urlToObject query on map load so as to pass x/y coordinates to an appbuilder map via url and zoom to location.  Any thoughts on where to insert code block?  This was pretty easy with default JS but my naivety on the builder is making this a bit more complicated than expected.  Widget model was first thought but I didn't see how to bypass adding button to ui while enabling code. Thanks in advance
RobertScheitlin__GISP
Jonathan,
  So here is what you need to change if you want to specify a center (Lat,Lng) and a zoom scale:
In the ConfigManager.js at line 606 > function _addDefaultMap  (Assuming Beta 2)
Add this to the end of the function:
      if(this.urlParams.center){
        config.map.mapOptions.center = this.urlParams.center;
      if(this.urlParams.scale){
        config.map.mapOptions.scale = this.urlParams.scale;
In the MapManager.js at line 261 > function _processMapOptions
Add this to end of function before return:
        if (ret.center){
          ret.center = ret.center.split(",");
That should be it. This is what the addition to the url would look like:
index.html?center=-84.391136,33.74579,&scale=72224
Jonathan,
   So are you wanting to set the maps extent in the url, just provide a point to center the map at, or a point to center the map at and a scale to zoom to?
Jonathan,
        if (ret.center){
JonathanPascoe
Works like a charm!  Thanks for the help.
Jonathan,
   Glad to help. You have marked my reply as helpful which is great. Marking a reply as helpful will help other user find reply that were helpful yet did not Answer the question. If the reply answered your question than you should click on the "Correct Answer" button (the one with the little green star) on the reply that answered your question, this will help other users find the correct answer.
JonathanPascoe
Didn't realize I had to do this from the Content tab to see the additional options.  That code has actually resolved some other rendering options that I had questions about.  So, Thanks again.
