URL field in Esearch Widget
2688
05-20-2016 08:52 AM
EmilyLaMunyon
Thanks Robert. I am using the version right before 2.0.1.3. I have attached the config_Enhanced Search file. Thank you so much!!!
RobertScheitlin__GISP
Emily,
  I am not sure how it happened but you do not have the subdir field listed in your layers field list thus the value of that field is not getting returned by the query.
Add lines 31 (just the comma) thru 35.
"fields": {
        "all": false,
        "field": [
            "name": "DOCUMENT_N",
            "alias": "Document Number"
            "name": "ADDRESS_OF_SURVEY",
            "alias": "Survey Address"
            "name": "SECTION",
            "alias": "Section"
            "name": "TOWNSHIP_RANGE",
            "alias": "Township/Range"
            "name": "SURVEYOR",
            "alias": "Surveyor"
            "name": "BUSINESS_NAME",
            "alias": "Business"
            "name": "page_id",
            "visible": false
            "name": "subdir",
            "visible": false
Emily,
"fields": {
        "all": false,
        "field": [
            "name": "SECTION",
            "alias": "Section"
            "name": "SURVEYOR",
            "alias": "Surveyor"
            "alias": "Business"
            "name": "page_id",
            "visible": false
            "name": "subdir",
            "visible": false
EmilyLaMunyon
That was it, everything is working!! Not sure how that happened either but now I know what to look for.
Thank you so much and I will definitely contribute to the beer fund. ☺
Emily,
  Don't forget to mark this as answered by clicking on the correct answer link on the reply that answered your question.
