Update a field
4500
02-05-2015 06:42 AM
MiriEshel
Hi everyone,
I'm trying to automatically update a date field with Date.now() value using the Edit widget with some changes.
What ever I do, it does not update the field.
Can someone tell me what's wrong with my code?
this.editor = new Editor(params, this.editDiv);
this.editor.startup();
var feature;
var attInspector = this.editor.attributeInspector;
attInspector.showObjectID = false;
var theMap = this.editor.settings.map;
var saveButton = new dijit.form.Button({label:"שלח","class":"saveButton"});
dojo.place(saveButton.domNode, attInspector.deleteBtn.domNode, "before");
saveButton.on("click", function(evt) {
  if (feature == null)
   alert("Pleae enter values");
  else {
   if (feature.attributes["description"] == null) {
      alert("Description field is required");
      return;
  feature.attributes["date1"] = Date.now();
   theMap.infoWindow.hide();
attInspector.on("attribute-change", function(evt) {
   feature = evt.feature;
   feature.getLayer().applyEdits(null, [feature], null);
theMap.infoWindow.resize(350, 600);
        this.resize();
Thanks a lot,
Miri
RobertScheitlin__GISP
Miri,
  Try this:
var currentDate = new Date();
var currentDate = Date.UTC(currentDate.getUTCFullYear(), currentDate.getUTCMonth(), currentDate.getUTCDate(), currentDate.getUTCHours(), currentDate.getUTCMinutes(), currentDate.getUTCSeconds(), 0);
   feature.attributes["date1"] = currentDate;
Reference thread: Re: Hard-code Attribute Values for Fields with AttributeInspector?
MiriEshel
Hi Robert,
Unfortunately it didn't help.
I think you ment to define two different variables, isn't it? something like:
var currentDate1 = Date.UTC(currentDate.getUTCFullYear(), currentDate.getUTCMonth(), currentDate.getUTCDate(), currentDate.getUTCHours(), currentDate.getUTCMinutes(), currentDate.getUTCSeconds(), 0);
   feature.attributes["date1"] = currentDate1
But anyway, both of them don't work.
I think it's more timimg Issue rather than the Date format. Only once, during Debug, I saw the date entered but I cannot reproduce it any more.
it's also related to the Editor or AttributeInspector classes in Javascript API rather than the Web AppBuilder.
Thanks a lot,
Miri
