Transformation from one projection to other
3360
08-12-2015 11:48 AM
RahmathUnissa
Hello,
I have created an app in Web Appbuilder, where the BaseMap has a spatial reference as say "A" and I using  a Map Service whose spatial reference as  say "B".
Q.1 How the Transformation from one projection to other is done?
Q.2 How can I get access to it? so that I can easily transform it in my widget.
Thank you.
Rahmath Unissa
RobertScheitlin__GISP
Rathmath,
   You will use the GeometryService to project the geometry.
GeometryService | API Reference | ArcGIS API for JavaScript
RahmathUnissa
Hey,
To Project a BaseMap in a Web AppBuilder  how do I give the below parameters:
params.outSR = outSR;
(Used  as  params.outSR = new SpatialReference({wkid:102100});  )
params.transformation = transformation;
Thank you,
Rahmath Unissa
Rahmath,
You can not project a basemap, you project geometries to match your your basemaps WKID.
