toggle Attribute
1336
03-09-2025 11:13 AM
Jacob_Martinez
Please guide me, this is my first post/question and a novice user.
I have a point layer representing traffic signal control devices that need to be reviewed. I want the users to be able to see which locations have not been reviewed in the field by the color of the point and be able to change the color as they are reviewed.
My thinking is I want to add a field "Signal_Reviewed" and having a "Yes" or "No" (or true/false) as predefined options. The default would be no (or false) and symbolized as one color (red) and once they are reviewed in the field the user could click/select the point and toggle to yes (or true) effectively changing their symbol color (green.)
I apologize for not knowing exactly where to search or ask for direction, I researching I tried various phrasing on how to do this (as I have done for numerous other learning goals) with no satisfying results.
Thanks in advance
Laura
by MVP Regular Contributor
I'm not entirely sure what you're asking, as it seems like you've already figured things out. For a similar purpose, I have fields set up with a yes/no domain. I would recommend setting this up in Experience Builder instead of Web AppBuilder. Additionally, you can control which attributes users can edit by configuring your smart forms in Map Viewer which you can set to show in the editor widget in EXB. The color will change automatically in the map once the edit is saved!
Laura
Jacob_Martinez
Thanks for the reply, I guess I was wondering which product would be best to use to achieve this. I will play around with experience builder, thanks again.
