this.color.toRgba () is not a Function
3349
10
09-12-2018 10:53 AM
ChristopherWiebke1
I am using the print widget and get the error "this.color.toRgba () is not a Function" when i try to print graphics created in my map from the Direction Distance widget?
KenBuja
MVP Esteemed Contributor
Is this within a function you are calling? If so, you'll probably need to use lang.hitch when calling the function, like this:
settings.forEach(lang.hitch(this, function (setting) {
ChristopherWiebke1
It is what the widgets are calling "out of the box".  I have not added any custom code.
KenBuja
In the console, where is this error occurring?
ChristopherWiebke1
KenBuja
And when you click on the link on the first line (Widget.js?wab_dv=2.8:153), is that the Print widget or another one?
ChristopherWiebke1
That is the print widget, and the error that comes from clicking the print button.  As I mentioned, this only happens after I have created a graphic from the Direction Distance widget.
ChristopherWiebke1
KenBuja
I get the same error when using the Distance and Directions widget with the Print widget. This is something you should report to Support.
ChristopherWiebke1
Will do.  thank you for your help.
