I want to narrow the width of the side controller for the tab theme if possible when switched to a mobile device. I was trying to play with the theme/widgets/sidecontroller css file and create a media response. Can someone please steer me in the right direction?
Much appreciated
Solved! Go to Solution.
Thanks Robert. This worked nicely. I used a media response so it affected only the app on a mobile platform. Can the sidebar controller on a tabbed theme have the ellipsis (...) button and that drop down menu at the top that turns all layers on/off removed? I saw a post about it for the foldable.
Brandon,
I am not sure I am following but if you are asking about the LayerList widget and removing the actions menu then the fact that you are using the tab theme has no bearing.
Yes. Removing the actions from the layer list widget.
Brandon,
In the LayerList widget settings if you un-check all the actions then the menu will not show.
I.e. un-check all of these:
| Zoom to | |
| Transparency | |
| Enable / Disable pop-up | |
| Move up / Move down | |
| View in Attribute Table | |
| Description / Show item details / Download |
Thanks. I will be sure to mark you answer as correct. ☺
Thanks Robert. This is good too. However, I was trying to see if a change to the scripts might work too since I have already downloaded the app onto my server. I found this: Remove popup menu from Layer List Widget. Will this still work with 2.5?
Thanks. This was great Robert.
I also was able create more text space by setting this to zero:
.jimu-widget-layerList .col3{
width: 0px;
-Brandon
