Tab Theme Side Controller
5247
18
09-20-2017 05:59 PM
BrandonPrice
I want to narrow the width of the side controller for the tab theme if possible when switched to a mobile device. I was trying to play with the theme/widgets/sidecontroller css file and create a media response. Can someone please steer me in the right direction?
Much appreciated
BrandonPrice
Thanks Robert. This worked nicely. I used a media response so it affected only the app on a mobile platform. Can the sidebar controller on a tabbed theme have the ellipsis (...) button and that drop down menu at the top that turns all layers on/off removed? I saw a post about it for the foldable.
RobertScheitlin__GISP
Brandon,
   I am not sure I am following but if you are asking about the LayerList widget and removing the actions menu then the fact that you are using the tab theme has no bearing.
BrandonPrice
Yes. Removing the actions from the layer list widget.
Brandon,
   In the LayerList widget settings if you un-check all the actions then the menu will not show.
I.e. un-check all of these:
Choose which actions will be shown on the layer context menu.
Zoom to
Transparency
Enable / Disable pop-up
Move up / Move down
View in Attribute Table
Description / Show item details / Download
BrandonPrice
Thanks. I will be sure to mark you answer as correct. ☺
BrandonPrice
Thanks Robert. This is good too. However, I was trying to see if a change to the scripts might work too since I have already downloaded the app onto my server. I found this: Remove popup menu from Layer List Widget. Will this still work with 2.5?
It should
BrandonPrice
Thanks. This was great Robert.
BrandonPrice
I also was able create more text space by setting this to zero:
.jimu-widget-layerList .col3{
width: 0px;
-Brandon
