Smart Mapping Custom Widget 4 WAB
6646
7
06-26-2015 03:44 AM
FabioD_Ovidio
Any news about Smart Mapping plugin?
RickeyFight
Fabio,
Can you provide an example to what you are thinking about for a "Smart Mapping plugin"?
FabioD_Ovidio
Hello,
I know (from Dev Summit) that the capabilities of Smart Mapping for AGOL will be delivered also for WAB as widget.
When more or less?
Thank you
Fabio
RobertScheitlin__GISP
Fabio,
   I do not see it in the list of widget coming in the next version so maybe it will make the one after.
StanMcShinsky
Fabio,
Smart Mapping is not a plug in or widget. It is part of the AGOL map. The capabilities and enhancements that smart mapping brings are default now in AGOL. When you create a new map in AGOL you have access to better tools to make your maps look better. You then add that web map to your Web AppBuilder and now you can add widgets to use the map better. Here is a blog post from esri about it
Introducing Smart Mapping | ArcGIS Blog
-Stan
FabioD_Ovidio
Hello and Thanks!
Sorry just to unserstand better your words: "You then add that web map to your Web AppBuilder and now you can add widgets to use the map better"
means that:
if I use Smart Mapping capability from AGOL, than I can use that map from WAB and change the thematism directly from WAB interface (both administrator and final user) as well as from AGOL interface by using widgets? (Which one?)
Thank you again
Fabio
StanMcShinsky
Fabio,
Smart mapping is just a catchy phrase to say that there are new capabilities in AGOL to create better looking maps from the defaults. It looks at your data and suggests good ways to view it.
Are asking for a way to change the symbology of the AGOL map from the end user side?
There is a smart mapping module in the api that says :
(Added at v3.13)
This module contains a collection of helper functions used to create pre-configured renderers for smart feature styling.
esri/renderers/smartMapping | API Reference | ArcGIS API for JavaScript
Here are some samples from the api that could be converted to a widget that would help to render the data on the fly.
Smart Mapping - Render class breaks with color | ArcGIS API for JavaScript
Smart Mapping - Show Data by Color | ArcGIS API for JavaScript
Generate renderer | ArcGIS API for JavaScript
Hope this helps some.
-Stan
JakalaSPA
Hello,
i mean something like this
http://maps.esri.com/AGSJS_Demos/UNData/index.html
is there anything like this in the road map of Web App builder widgets or custom widgets?
Thank you very much!
Fabio
