Show include text query in selection
2074
06-08-2017 01:02 PM
RudoDuncan
Is there a way to make the show include text query in selection checked by default? I was looking through your code but couldn't find it.
rscheitlin
Roberts Custom WAB Widgets
Tags (1)
RobertScheitlin__GISP
Rudo,
   I am confused it is checked by default.
RudoDuncan
Sorry it is unchecked by default as shown below. I don't know if there is an option of checking it in by default in your configuration.
Rudo,
   OK that is a different image (that is the actual widget UI and not the settings UI like you showed before). To check that by default you will need to modify the Widget.html as there is no setting for that to be checked in the configuration.
Open the Widget.html and search for "cbxAddTextQuery" and change the
data-dojo-props="checked: false,
to
data-dojo-props="checked: true,
RudoDuncan
Thank you Robert, so if I want to make changes to the configurations manually, I will look in the widget UI correct?
Rudo,
  In my last reply I tell you specifically what you need to do.
