Share Widget
2016
12-28-2018 07:02 AM
GarethYoung1
Robert Scheitlin, GISP
Robert, Is there a way to remove all the link options from the share widget apart from the  following:
  • Current map extent
  • Add a marker on the map
Under the marker options is there a way to remove the WKID option?
Thanks
Gareth
RobertScheitlin__GISP
Gareth,
  Add these rules to your apps theme common.css:
.share-container .shareLink .optionsRow:nth-child(2),
.share-container .shareLink .optionsRow:nth-child(3),
.share-container .shareLink .optionsRow:nth-child(4),
.share-container .shareLink .optionsRow:nth-child(5){
  display: none;
.share-container .shareLink .optionsRow.shareClearFix:nth-child(1){
  display: none;
.share-container .shareLink .moreOptionsRow:nth-child(1){
  display: none;
For changing the email text you have to edit the shareEmailTxt1, shareEmailTxt2, shareEmailTxt3 properties in the apps jimu.js\nls\main.js
GarethYoung1
I'd also like to customise the subject and content of the email generated from the email button:
Gareth,
  display: none;
  display: none;
  display: none;
GarethYoung1
Thanks Robert.  This resolved my issue
